IP routing not enabled
petnan
Hi folks!
A simple problem ( I hope so..) I've configured Cisco 2600, IOS version 12.1(6) with IP addresses for the 3 interfaces (e0,e1 and s0. When I enter the router rip command. The message displayed in "IP routing not enabled". Anyhelp would be appreciated.
6 Replies 6
ggehle
Try entering "ip routing" in your config to see of that makes a difference.
tnx ggehle, the ip routing command resolved d isuue
thank you so much,   one more time with arabic جزاكم الله خيرا
jscinocca
from config term
type "routing ip"
jscinocca
i meant ip routing
Remember
Without enabling (ip routing) your routing protocol will not work.
Can I ask why are you using RIP? or RIP2 ??
