Possible memory leak on Cisco 3660
kongalex
Hi!
I have problems with a Cisco 3660, which just freezes after a couple of months. Therefore I ran "show tech-support" and used it with the Stack decoder. I am using IOS 12.2(1) Enterprise.
A thing the output intrepreter commented was the following:
ERROR: The following processes are currently holding more than 1MB of memory:
IP-EIGRP Router (Holding 1411784 bytes)
This is considered to be high and can indicate a memory leak.
Are anyone of you familiar with such a problem (with Enhanced EIGRP), do anyone have a suggestion what I should do next?
ahvn
Routing protocol you run is memory intensive . You have not specified how much memory you have right now.So its hard to comment the exact cause for the the problem. Then also I feel that you are shoprt of memory.
Rgds,
Homin
