Configuring point to point leased line
rmrahman0302
I have two locations are connected via full T1 leased line. Hardware is Cisco 1721 router. I did configure encapsulation type to Cisco and LMI type to Cisco. Also I did configure service-module T1 source line on one location. Service provider is working on the T1 line. I want to verify that my configuration is ok.
Appreciate your help.
vmiller
Level 7
Level 7
Is your T-1 Frame relay?
Yes
configure the device at the far end the same. your carrier should provide you the necessary frame relay information (dlci). double check with them on the LMI type
