“CAS Cannot Establish Secure Connection to CAM”
fouzi
I have a problem with NAC
"cas Can not Establish Secure Connection to CAM"
the error message in the CAS is "Encountered error.unable to connect to manager.javax.net.ssl.SSLHandshakeException: Remote host closed connection during handshake"
e.bayon
Check the current time for CAM and CAS, it must be in 300 segs max interval of different.
Check the SSL autogenerate certified if you are used it.
