07-31-2001 06:52 AM - edited 03-08-2019 08:32 PM
I have a client who has a 2611 Router with IOS 12.0. I have looked all over Cisco's web site and cant find how to configure it for Port Forwading. I just need to set up a simply redirection of a port to a internal IP.
Is this not possable on a 2611?
Any help would be great.
Zack Harling
08-12-2001 09:45 AM
The topic of this forum is General Security however there are a number of professionals online who may be able to assist you. We are always considering additional forums for such topics and I will make a note of your post.
If you don't get a suitable response to your post, you may wish to review our resources at the online Technical Assistance Center http://www.cisco.com/tac or speak with a TAC engineer. You can open a TAC case online at http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
08-20-2001 10:15 AM
TCP or UDP ? If its forwarding out udp datagrams to
a specific host, and, Its not one of the common udp
ports (i.e. dhcp stuff), then, on the inbound interface configure ip helper-address xxx.xxx.xxx.xxx
whre xxx is the destination address. also configure
ip forward-protocol xxxx where xxxx is the udp port
you wish forwarded.
08-20-2001 03:25 PM
From your brief description, it is difficult to tell exactly what you are wanting to accomplish. A specific example would be helpful. Perhaps you need to use NAT here - you would assign an address such as 192.168.1.1 to the ethernet0 interface, but when packets hit that address on port 80 they are then sent on/forwarded to another pc. In this fashion, you can have multiple pc's using the same public ip address, just assigned to different ports e.g. 80 for the http server, 21 for the ftp server, etc. If this is what you are shooting for I can dish out some good samples, but specifics would help.
Good luck!
