2nd outside IP on a PIX-515e?
gzullich
Hi, I am wondering if it is possible to assign a 2nd IP to the outside interface on a PIX-515e?
TIA
drolemc
Level 6
Level 6
This can be done if your PIX is running version 6.3.
mhoda
Level 5
Level 5
Yes, with the VLAN interfaces as shown in the following link -
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_sw/v_63/cmdref/gl.htm#wp1075586
As the previous post mentioned, only available from version 6.3 and above.
Mynul
Thanks for the reply!
Will this allow an outside interface to listen to 2 IPs?
TIA
