404 error when accessing PDM - please help
explorer515
Hi guys!
Just bought an older PIX515 (6.3), recovered the password and went through setup. The thing is - whenever I try to access PDM via browser, I'm getting 404 message :(.
I haven't found anything about this in Cisco docs, nor forums. I wanted to re-install 6.3 PIX version but I'm not able to download the image file (the page says, no packages are available). I cannot upgrade to 7.0 because of the 64 MB memory (I have no budget to buy additional one). I'm getting hopeless :(.
Just summary:
- PIX515
- clean setup
- HTTP server running, able to access and authenticate via browser
- CLI pdm commands work fine
- getting "404 not found" error every time, when trying to go for PDM
Can you point me to something? Or suggest?
Thanks in advance!
Karel
explorer515
Forget it, sorted it out already .. I was just stupid :).
Cheers,
Karel
what was the solution, I have having the same issue. Pix 515 v.7.0
thanks,
Mike
Add HTTP "10.X.X.X 255.255.255.255 lan" that should let you in
