802.1x and EAP
sarahr202
Level 5
Level 5
Hi every body
How is everybody doing?
Does 802.1x require the usage of EAP ? or can we use 802.1x without using EAP?
thanks and have a geat weekend.
hi sarah,
802.1x uses the EAP framework if you will. As you pointed out, it uses supplicant, authenticator, authentication server to authenticate, authorise a client.
I don't think you can use 802.1x without EAP because you have to some framework to allow the client to authenticate etc.
thats just my opinion
Kishore
sarahr202
Level 5
Level 5
That is what I found.
The 802.1x protocol uses EAP protocol which in turn defines different eap messages.,Supplicant ,authenticator and radius server.
hi sarah,
Kishore
