802.1x with MDA
Rodrigo Gurriti
Level 3
Level 3
Gentlemen,
I want to know if there is a easy way to use 802.1x on phones. All the documentation I found tells me that I have to either install certificates(EAP-TLS) on each of them or input each phone's login and password (EAP-MD5) on the ACS.
Does anyone have a easier way to deploy them ?
Thankyou
Faisal Sehbai
Level 7
Level 7
Rodrigo,
You could do MAB with them too: http://tinyurl.com/26sj3jd
HTH,
Faisal
