12-06-2000 08:00 AM - edited 03-08-2019 07:51 PM
1)Assume a PE connecting 10 sites of company,must I config 10 VRF tables? when my MPLS-VPN has 1K VPN-clients,whether I must config 1k VRFs in PE?
2)
router(config)#ip vrf vrf-name
router(config-vrf)#rd 100:1
router(config-vrf)#route-target both 100:1
My question is about format of rd.Look the example,'100' signify the RD,but what meaning about the '1',is it a outer label distinguishing ip address of the same site?
12-19-2000 01:20 PM
Ive run into a similar situation and couldnt find anything to help me out. If you find an answer please be sure to post it on the board for everyone. Thanks
12-21-2000 11:45 AM
I have worked with MPLS in the lab and discovered the following. MPLS RD tags can be of the following
form AS#:1 or IP Address:1. This is the format.
Once you create the vrf name, you must then
apply the VRF to the interface. Always apply the vrf name to the interface first, since it will wipe out the ip address.
interface eth0/0
ip vrf vrf-name
ip address
There should only be 1 VRF table for the ten sites you are configuring. VRF tables apply to the whole VPN.
