ACS2.6 Radius with Netscreen xAuth
ryanjgs
hello professional,
in order to configure xauth with radius, netscreen provide radius.dct to be loaded into radius server. Cisco Radius Unix version can be done.
My problem is:
1) for ACS 2.6 Window NT/2000 version, how do i update the dictionary files ?
any suggestion is appreciated.
thanks.
jekrauss
Not possible in ACS 2.6. However, you can do this in ACS 3.0 and above.
See the ACS 3.0 release notes:
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_soft/csacs4nt/csnt30/rn301.htm#xtocid5
Here's how you add user-defined VSA:
Adding a Custom RADIUS Vendor and VSA Set
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_soft/csacs4nt/csnt30/user/ae.htm#xtocid1602228
Jeff
thanks.
