Adding sensor in IDSMC using a SSH highport
msmitha
We are using VMS 2.2 and IDSMC 1.2 for management. Some of our Cisco IDS devices are in remote networks which are not directly accessible from VMS hosts. There is a proxy host in between which can listen on a high-TCP-port and port-forward SSH and SSL connections to Cisco IDS devices in these remote networks. In order to get to the Cisco IDS devices, we need to connect to the high-TCP-port on the proxy host.
I'm able to use SecMon to get to a high TCP port for SSL (RDEP properties) but I'm unable to use IDSMC to connect on any port other than 22 for SSH. Please let me know how I can get IDSMC to connect on a port other than 22. Thanks for the help.
ywadhavk
IDSMC can talk to IDS only on port 22, while as as you figured out, the port on which Secmon talks can be altered.
thanks,
yatin
How can I request a feature enhancement for the IDSMC to support this?
