Additional Custom Signature for the SysV /bin/login Overflow
mcerha
Level 3
Level 3
This is a new custom signature entry for the recent SysV /bin/login Buffer Overflow referenced in CERT Advisory CA-2001-34. This signature is provided as a supplement to S13 signatures 3403 and 3501 to better detect any attacks. It will be incorporated into a future signature update. Listed below is a sample screenshot of the output of the SigWizMenu tool. Please refer to the sensor Release Notes for instructions on how to use the SigWizMenu tool to add a custom signature.
Tune Signature Parameters : CSIDS Signature Wizard
___________________________________________________________________________
Current Signature: Engine STRING.TCP SIGID 20000
SigName: SysV /bin/login Overflow
0 - Edit ALL Parameters
1 - AlarmInterval =
2 - AlarmThrottle = FireOnce
3 - ChokeThreshold =
4 - Direction = ToService
5 - FlipAddr =
6 - MaxInspectLength =
7 - MinHits = 1
8 - MinMatchLength =
9 - MultipleHits =
10 * RegexString = ([ \t][^ =\r\n]*[=][^ =\r\n][\x00-x7F]*){5}[\x00-\xff]*[\x80-\xff]
11 - ResetAfterIdle = 15
12 - ServicePorts = 23,513
13 - SigComment =
14 - SigName = SysV /bin/login Overflow
15 - SigStringInfo = /bin/login x1=1 x2=2...
16 - StripTelnetOptions = TRUE
17 - ThrottleInterval =
18 - WantFrag =
d - Delete a value
u - UNDO and continue
x - SAVE and continue
dlac455
How should we manage custom signatures over the long term? Are they added to subsequent signature releases? If so, should we then go back and remove the custom ones at some point?
All custom signatures are included in later releases. Once a signature update is release, all prior custom signatures should be covered in the release. The custom signature releases are used only for signatures that have serious 0-day implications and cannot wait for the usual two week release. Those signatures then make it into the next signature update.
