Allow FTP to DMZ
wraights
I have a server on my DMZ that I want to allow people to FTP to.
I want to allow only specific IP addresses. This is what I have done and *I think* that it works, but I am seeing no hits on it.
What I have done is created access-lists below:
access-list name permit tcp host 63.0.1.2 host 34.9.35.2 eq ftp
63.0.1.2 is the clients specific IP address and the 34.9.35.2 ip address is our FTP server.
I am seeing no hits on the access-list, yet when I do that, they are able to ftp. Up until now. There is one client that I have added an access-list for and they still can't FTP. Any clue?
Am I doing this wrong or what? Any input is greatly appreciated!
SMW
rickan2000
have you assigned your access-list to the interface outside?
Ummm...you know what...no.
But I tried it and no traffic was allowed through after that. I couldn't even surf. What am I doing wrong?
What I am doing with other access-lists is this:
I add them through nat. So there is one access-list that I have created for VPN users and they have to access a server on the DMZ so I have the command:
nat (dmza) access-list 101
Is that what I should do with these other access-lists?
Man I think I am a little slow...Thanks for the help!
wraights
When I do bind that to the DMZ interface it gives me this error:
WARNING: access-list protocol or port will not be used
What does that mean. And when I try to bind other access-lists to that dmz it replaces the other one instead of adding it in.
I think I have something wrong. What is it?
wraights
Never mind...I decided to use a conduit permit command instead and that worked fine.
conduit permit tcp host x.x.x.x eq ftp host x.x.x.x
Thanks for helping anyways!
