ASA logging buffer
cisco8887
Level 5
Level 5
Hi All,
When you look under logging buffer size , it is from 4096 byte to 1048576 which is about a MB.
Is there any downside to enableling the full1Mb ?
On an asa that has 8Gb of RAM that is nothing right?
Is it stored in RAM or FLASH?
Is ASDM buffer different from console buffer?
Many thanks
XYZ(config)# logging buffer-size ?
configure mode commands/options:
  <4096-1048576>  Specify logging buffer size in byt
pravintheprofessional
Community Member
Yes the ASDM buffer is different from console, its one of the virtual terminals like telnet buts HTTPS,
please follow the below like to learn more about the buffer memories and commands for cisco ASA
http://www.cisco.com/c/en/us/td/docs/security/asa/asa84/configuration/guide/asa_84_cli_config/monitor_syslog.html#wp1133360
Praveen Kumar Balasundaram
Spooster IT services
