08-21-2006 08:49 AM - edited 03-09-2019 03:57 PM
I am going to replace my old firewall with a new ASA 5510, I have never configured a cisco firewall and I wanted to find a guide for basic configuration such as publishing web sites, ms-exchange server. Is it possible to configure multiple public ip addresses and how on the outside interface. How do you publish multiple web sites behind the DMZ?
Thanks for all of the help.
Paolo
08-21-2006 10:53 AM
You need this for command line configuration:
Example configurations:
http://www.cisco.com/en/US/customer/products/ps6120/prod_configuration_examples_list.html
HTH pls rate!
08-21-2006 11:13 AM
Thanks for your reply, but when I try those 2 links, I am asked a logon id and password, and when I try the ones I registered for the forum, they do not work
Can you attach the scripts to your next reply?
Paolo
