ASDM fails to load on MacOSX 10.7 running Java version 1.6.0_33
femi.agboade
So I have an ASA 5510 running ASDM 6.4(9) and Cisco Adaptive Security Appliance Software Version 8.4(4)1.
I am trying to configure for the first time and I am accessing the ASA via its Management Interface.
I am successfully able to connect to the device and get to the Cisco ASDM 6.4(9) page.
When I try to run the startup wizard, a couple of prompts displays up to the point where the java applet runs and aks me to enter my IP, username and password. As it is a new system, password and username is blank so I enter and I get a message saying "loading software from cache" which later changes to "software Update completed" and then nothing happens.
I am running MacOSX 10.7 Lion, Java version 1.6.0_33.
I did try and run this on a Windows system and i was able to load the interface.
Does anyone have any advice as to what to tweak or change with the java software on my Mac as I imagine this may be the problem?
Femi
femi.agboade
Here's the trace from the java webstart:
Java Web Start 1.6.0_33
Using JRE version 1.6.0_33-b03-424-11M3720 Java HotSpot(TM) 64-Bit Server VM
User home directory = /Users/Femi
c:   clear console window
f:   finalize objects on finalization queue
g:   garbage collect
h:   display this help message
m:   print memory usage
o:   trigger logging
p:   reload proxy configuration
q:   hide console
r:   reload policy configuration
s:   dump system and deployment properties
t:   dump thread list
v:   dump thread stack
0-5: set trace level to
Application Logging Started at Tue Jun 26 12:32:05 WAT 2012
Local Launcher Version = 1.5.55
Local Launcher Version Display = 1.5(55)
OK button clicked
Trying for ASDM Version file; url = https://192.168.1.1/admin/
Server Version = 6.4(9)
Server Launcher Version = 1.5.55, size = 757760 bytes
invoking SGZ Loader..
Cache location = /Users/Femi/.asdm/cache
Exception in thread "SGZ Loader: launchSgzApplet" java.lang.IncompatibleClassChangeError: Implementing class
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClassCond(ClassLoader.java:631)
at java.lang.ClassLoader.defineClass(ClassLoader.java:615)
at com.cisco.nm.dice.loader.l.loadClass(DashoA19*..:232)
at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
at com.cisco.pdm.util.Env.(Env.java:80)
at com.cisco.pdm.PDMApplet.start(PDMApplet.java:67)
at com.cisco.nm.dice.loader.r.run(DashoA19*..:410)
For some strange reason, i am also unable to launch from my web browser. When i get to the point of putting in my username and password, the same behaviour as above is observed. I get the error from the java page and the login just freezes.
Please help as I have to make do with a VM running XP which tends to slow down my Mac.
Femi
I'm having the same or similar issue, I'm afriad. I'm also looking for an answer. The launcher quits after entering the login details.
I don't have easy access to a Windows machine, and this is really holding me up.
