04-24-2007 03:41 PM - edited 03-09-2019 05:51 PM
Hi I have the following setup:
(Checkpoint) --- (Cisco 827) --- (Internet)
(192.168.2.1)--- (2.2)-(10.1.1.1)-(10.1.1.2)
There is only one public internet address on the 827.
my questions are:
1. Is there any way to make the 827 completely transparent so all traffic goes to the Firewall?
2. If 1. is possible would VPN Clients beable to talk to the checkpoint firewall?
Here is what i've got so far in my lab but I think I'm missing something more on the NAT side.
LABWAN#sh run
Building configuration...
Current configuration : 1228 bytes
version 12.3
service config
hostname LABWAN
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
memory-size iomem 10
no network-clock-participate slot 1
no network-clock-participate wic 0
ip subnet-zero
ip cef
no ip dhcp use vrf connected
no ip ips deny-action ips-interface
no ftp-server write-enable
no crypto isakmp ccm
interface FastEthernet0/0
ip address 192.168.2.2 255.255.255.0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.1.1.1 255.255.255.0
ip nat outside
duplex auto
speed auto
ip default-gateway 10.1.1.2
ip classless
ip route 0.0.0.0 0.0.0.0 10.1.1.2
ip http server
no ip http secure-server
ip nat inside source static 192.168.2.1 interface FastEthernet0/1
control-plane
line con 0
line aux 0
line vty 0 4
end
Gus
04-25-2007 05:46 PM
Greetings Gus,
Yes, that should pass all the traffic (including vpn traffic) coming from the Internet to the Checkpoint firewall.
You can also put the aboce statement as:
ip nat inside source static 192.168.2.1 x.x.x.x
(where x.x.x.x is your internet ip address)
The only catch would be that, you wont be able to access your router using telnet or ssh from the Internet side.
And if you want to do that, you can do it as:
For NAT:
ip nat inside source static tcp 192.168.2.2 23 x.x.x.x 23
For ssh use the port 22 in the above statement.
Hope that helps,
Good Luck
* Please rate if helpful
04-25-2007 06:26 PM
Sorry Gus,
I think the above is partially correct.
Reads: On the interface labelled "inside" when a packet from 192.168.2.1, translate it to x.x.x.x where x.x.x.x is your internet ip.
If you want your vpn clients to connect to your firewall you will have to forward either specific ports or forward all the traffic:
ip nat outside source static x.x.x.x 10.32.15.88 extendible
* Please rate if it helps
