02-06-2009 07:49 AM - edited 03-09-2019 10:01 PM
Hi all,
Can any one please tell me if it is possible to completely block the use of Skype on an internal network using an 877 ADSL router. I am running advanced ip services 124-15.T8.
I have read, followed and implemented the cisco document "Cisco IOS Flexible Packet Matching(FPM) Getting started with Cisco IOS FLexible Packet Matching", which gives an example of blocking Skype at the end. However, even though I can see certain Skype traffic being blocked (01116: Feb 6 2009 15:42:17.308 GMT: %SEC-6-IPACCESSLOGP: list skype denied tcp
192.168.1.11(1185) (Vlan1 ) -> 193.88.8.59(12350), 7 packets), skype clients are still able to log in successfully.
Any help would be gratefuly accepted as this is driving me up the wall and around the bend.
Ryan
Solved! Go to Solution.
03-12-2009 08:09 AM
hi, I even find another way to block skype version 4!!!
config:
load protocol system:/fpm/phdf/ip.phdf
load protocol system:/fpm/phdf/tcp.phdf
class-map type stack match-all ip_tcp
match field IP protocol eq 6 next TCP
class-map type access-control match-all skype
match start TCP payload-start offset 0 size 4 eq 0x17030100
policy-map type access-control child
class skype
log
drop
policy-map type access-control parent
class ip_tcp
service-policy child
int vlan1
service-policy type access-control input parent
int fastEthernet 4
I've tryed it and works fine.
With this config you even don't need the policy for protocol-violation.
Good luck!
03-18-2009 05:20 AM
Hi again,
Apologies for the delay, been rushed off my feet on other projects.
I have tried implementing the FPM solution previously but it failed, but I thought I would give it another go. The first hitch I came across was with the line
"match field IP protocol eq 6 next TCP"
my ios wouldn't except the "IP", only offering a "layer" option after the match field section.
Any ideas?
Ryan
03-18-2009 07:31 AM
Ignore the last entry that was me being silly and forgeting to load the phdf files. I have tried it though and I have had the same results as previously using the FPM solution e.g. I am still getting through with skype.
I have upgraded my IOS to c870-advipservicesk9-mz.124-24.T.bin
