Blocking timeout
8dstaicu
I use IDS v4 and blocking device is a Pix v6.2.
Is there a way to configure blocking period?
I can't find in current version blocking timeout.
And for specific signatures I think it should be perfect to be able to set this timeout.
Thank you.
kleem
You can configure the shun timeout value with the following CLI commands:
conf terminal
service virtual-sensor-configuration virtualSensor
tune-micro-engines
shunTime 15
You will be able to use IDM to configure the value in the 4.1 release.
I found the setting under tune-micro-engines ->ShunEvent
It is planned to be a per signature setting?
Thank you
No, the Shun Time is currently a global setting.
