09-07-2005 07:33 AM - edited 03-09-2019 12:21 PM
Right now, all of our outbound traffic uses our PAT address as the source IP, which is great for everything except email. We had to "cheat" and add a reverse PTR record for our email server that resolves to the PAT address instead of the IP address that's listed in our MX record.
Unfortunately, we are moving ISPs and the new ISP won't allow fudging the PTR.
Is there anyway to setup the PIX to not use the PAT address and use the external IP address as the source address when sending outbound SMTP traffic? I want all outbound SMTP traffic to go out the same external IP address that inbound traffic is received on. I know enough about the PIX to be dangerous, but I'm not connecting the dots on this one.
Can anyone help me out?
09-07-2005 12:08 PM
William,
How many public IP address do you have? I dont quite follow your question, if your MX record for SMTP is pointing to (as an example) to IP 222.222.222.222 then you can map this IP address to your inside mail server (I presume the mail server is on the inside network) for SMTP i.e.
access-list smtp permit tcp any host 222.222.222.222 eq smtp
access-group smtp in interface outside
static (inside,outside) tcp 222.222.222.222 smtp
write mem and clear xlate.
This way any e-mail internet headers will show that the e-mail is being delivered from IP 222.222.222.222 instead of your PIX outside IP address (PAT address).
Or am I misreading your question?
Let me know.
Jay
09-07-2005 12:35 PM
We have about 30 IP addresses. Each individual website we host has its own IP, as well as the email server, and there is a unique PAT address. The email server is indeed on the inside of the network.
I do have an access-list statement and the static statement you listed already in place for the email server, except mine looks like this:
static (inside,outside) 222.222.222.222
It doesn't have the "smtp" before the netmask part of the static statement.
the access-list looks like this:
access-list outside_acl permit tcp any host 222.222.222.222 eq smtp
and it is applied to the to the outside interface with this statement:
access-group outside_acl in interface outside
Currently, if I look at the message headers of an email, the originating IP is the address of the PAT(222.222.222.221), and not the external IP of email server(222.222.222.222).
09-07-2005 05:22 PM
the static nat should have higher priority than pat.
have you clear the xlate after applying the static nat? if not, then do
clear xlate local
also do "sh xlate" to verify whether the pix is doing the static nat.
you should see sth like
Global 222.222.222.222 Local
09-08-2005 07:55 AM
yes, I do see this:
however, I think I may have found the problem. OUr email server is part of a cluster, and therefore has multiple IP addresses. One for the virtual SMTP server and one for the teamed NIC. When I ran the "sh xlate", I noticed that I also got this line:
PAT Global
so I think my issue is that the email server is sending from the wrong interface. Does that make sense?
where the
09-08-2005 11:33 AM
Here's what I was thinking about doing in order to "fix" the issue:
- Create a new PAT address of 222.222.222.223
global (outside) 2 222.222.222.223
- Create 2 static routes for the two cluster servers
nat (inside) 2 192.168.1.10 255.255.255.254 0 0
(the two internal cluster IPs are 192.168.1.10 and .11)
- Create another MX record mail2.mydomain.com with a weight of 100 and an associated PTR record that points to the external IP address of the new PAT address 222.222.222.223
My only concern is that there is an existing NAT on the PIX that NATs "192.168.1.0" already. Will the IOS allow me two define the two specific IPs or will I need to remove the "blanket" NAT first and cut out the two IPs that I want to use for the new PAT?
ie:
change:
nat (inside) 1 192.168.1.0 255.255.255.0 0 0
to:
nat (inside) 1 192.168.1.1-192.168.1.9
nat (inside) 1 192.168.1.12-192.168.1.254
I wish I knew more, but this is a little over my head. Can someone point me in the write direction with correct syntax?
09-08-2005 11:13 PM
you mentioned you've got this command,
static (inside,outside) 222.222.222.222 192.168.1.10 netmask 255.255.255.255 0 0
so you add another one
static (inside,outside) 222.222.222.223 192.168.1.11 netmask 255.255.255.255 0 0
at the same time, you do need to create another acl for .223
further you don't need to worry about the existing pat, as i mentioned, static nat will always have higher priority than pat.
do remeber to clear xlate after you add the new static nat.
09-09-2005 06:17 AM
not sure what happened to my reply. for some reason it did not post and I'm too lazy to retype it all.
Basically, there are 3 internal IPs that we need to out the external mail IP (222.222.222.222). The first internal address is the virtual SMTP cluster IP address, which is statically mapped to the external IP. Incoming email works just fine.
We would like outbound email to go out that 222.222.222.222 IP address, but I've been told from someone at MS that it is impossible to force cluster members to use the virtual IP address as the sorce address. The cluster members use their own physical NIC IPs. If we could spoof some type of translation/routing so that anything originating from the two physical NICs exited the PIX with the 222.222.222.222 address, that would clear up the issue. But I don't think that's possible.
We've been kicking around a couple ideas, and here's what we have come up with. Unfortunately, I am not a PIX IOS expert, so I don't know if this is even possible.
We have this:
Virtual SMTP Server IP - 192.168.1.9
Server1 Physical NIC - 192.168.1.10
Server2 Physical NIC - 192.168.1.11
global (outside) 1 222.222.222.225
static (inside,outside) 222.222.222.222 192.168.1.9 netmask 255.255.255.255 0 0
We are thinking of this:
-add a second PAT (global (outside) 1 222.222.222.226)
-change our external DNS for mail.mydomain.com to point to the new PAT 222.222.222.226 (weight 50)
-add a DNS record for mail2.mydomain.com to point to the original mail IP 222.222.222.222 (weight 10)
-add a NAT statement so that traffic from the 2 physical NICs uses the new PAT (nat(inside) 2 192.168.1.10 255.255.254.0 0 0)
Inbound email shouldn't care about the DNS name, it'll deliver to the mail2 MX record because it has a lower cost and go right to the original IP and pass thru the PIX to the Virtual SMTP cluster IP.
This way outbound email has a PTR record that resolves to mail.mydomain.com and any sent email will resolve to mail.mydomain.com with a matching PTR record. Problem solved?
issues?
will the NAT statement direct outbound traffic thru the 2nd PAT?
do I need to exclude the two address in the new NAT from the old NAT?
09-18-2005 10:32 PM
i thought that the servers will be intelligent enough to handle the traffic.
i had configured 3 web servers cluter behind a dmz. all i need was to create a static to the virtual ip (in fact i did port forwarding since there's on 1 public ip) and "sysopt noproxyarp inside"
