Can you set the NIC speed on a 4210's sniffing interface?
jballay
Does anyone know if you can peg the sniffing interface speed on a 4210 to 10 meg? Also, is there a command you can run on the sensor to see what speed you are at with both iprb0 and iprb1? Thanks!
marcabal
There is no method that I am aware of to set the sniffing interface to 10MB or to determine whether the interface is set at 10 MB or 100MB from a command. The only method I am aware of is to check the switch or hub to which the interface has been plugged to determine what setting is being used.
