Cisco 3640 Slot0: unavailable
Hi all,
I tried to upgrade the firmware in my 3640. After introduce one flash and not possible to manage files in the slot I rebooted the system.
Slot is not know in show file system command but in Show ver is correct.
show file systems
File Systems:
     Size(b)     Free(b)      Type  Flags  Prefixes
           -           -    opaque     rw   system:
      129016       44120     nvram     rw   nvram:
           -           -    opaque     rw   null:
           -           -   network     rw   tftp:
*   33030140    12919608     flash     rw   flash:
    16515068     1011092     flash     rw   slot1:
           -           -    opaque     ro   xmodem:
           -           -    opaque     ro   ymodem:
125K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
20480K bytes of processor board PCMCIA Slot0 flash (Read/Write)
16384K bytes of processor board PCMCIA Slot1 flash (Read/Write) 125K bytes of non-volatile configuration memory.
After that we replaced the card for another and any card is recognised in that slot. I reboot again and slot0: is still not found!!
For other hand no news files are seen in slot1: when introduced new card (we try with 3 cards) Only original card is recognised.
Do you have any idea?
Thanks a lot!
Víctor
3640 only support cards minor of 32Mb in slot. I will try to do a partition in a Flash.
