Cisco 678 Setting filter rules help please
tedjordan
I have a LAN connected to WAN via Cisco 678. In between
the Cisco and the LAN is a NAT-ed switch. (network values
have been changed to protect the innocent)
Cisco to Switch network is 200.50.100.0
The LAN network is 192.168.10.0
Let's say for example that I want to allow the following
from the WAN into the LAN
100.50.7.0 - allow network to access LAN
100.70.8.8 - allow system to access LAN
100.90.9.0 - allow network to access LAN for FTP & Telnet only
100.100.10.7 - allow system to access LAN for FTP & Telnet only
deny anything else
Allow users on LAN to ftp, telnet, send/recv email, etc. to internet
so i setup some rules like so:
set filter 0 on allow incoming all 100.50.7.0 255.255.255.0
0.0.0.0 0.0.0.0 protocol TCP srcport 1-65535 destport 1-65535
set filter 1 on allow incoming all 100.70.8.8 255.255.255.255
set filter 2 on allow incoming all 100.90.9.0 255.255.255.0
0.0.0.0 0.0.0.0 protocol TCP srcport 1-65535 destport 23-23
set filter 3 on allow incoming all 100.90.9.0 255.255.255.0
0.0.0.0 0.0.0.0 protocol TCP srcport 1-65535 destport 21-21
set filter 4 on allow incoming all 100.100.10.7 255.255.255.255
set filter 5 on allow incoming all 100.100.10.7 255.255.255.255
set filter 6 on allow outgoing all 0.0.0.0 0.0.0.0
--- end of rules
okay, the last line was put in so that I could send mail from LAN
etc. Unfortunately, nothing could come in so I set up this rule
set filter 7 on allow incoming all 0.0.0.0 0.0.0.0
which works great, but allows everything in, including addresses
I do not want to allow.
How do I lock out the work except for the networks and systems I
want to allow, and at the same time allow the users in the LAN to
use the internet?
thanx
ted
thomas.chen
Level 6
Level 6
To learn more about configuring filters on your 678, you could refer to the 'set filter' command at http://www.cisco.com/en/US/products/sw/netmgtsw/ps528/products_user_guide_chapter09186a00800ead58.html#xtocid15
The relevant sections explain the command and also discusses a number of examples.
You could also refer to 'Filter Configuration Screen' at the URL
http://www.cisco.com/en/US/products/sw/netmgtsw/ps528/products_user_guide_chapter09186a00800ead57.html#xtocid15
