Cisco ASA - Syslog ID Numbers
guybrr
According to table 43 in Cisco ASA docs:
https://www.cisco.com/c/en/us/td/docs/security/asa/syslog/b_syslog/about.html#con_4768518
the syslog logs of Cisco ASA suppose to contain a message ID of 3 numbers that indicates the type of the log.
I can't find that in my logs, but I can see the Message_number, for example (722051):
<164>Mar 21 2024 14:28:12: %ASA-4-722051: Group <ab-cd-efg-hhh-123> User <user.name@gmail.com> IP <8.8.8.8> IPv4 Address <10.0.0.1> IPv6 address <::> assigned to session
are the three first numbers of the message number correlates with the message ID? Which means in this case - SSL VPN Client?
In same link you share
Message number
A unique six-digit number that identifies the syslog message.
As I understand the first three digits for message class (also this show in link).
And yes this syslog for ssl vpn.
MHM
Thanks for the fast response.
Yes, the problem is that there is message_id in the table and message_number in the log format description.
I assumed that the first 3 are the class but it is not mentioned anywhere.
