Cisco Catalyst Blade Switch 3020 for HP
armands_t
Can anyone tell what is the Default username and password for "Cisco Catalyst Blade Switch 3020 for HP"?
After reset to factory default we have LAN connection but we can not log in.
Br, Armands
Yes, you understand it correctly.
If you pressed enter and you got error login or wrong username, this means that the device already have configured user and pass, so go with password recovery
Moaz Elzhrawey
Solutions Architect, CCIE 2x RS | DC, VCP 3x NV | DCV | DTM
+966 596822551
Moaz.Elzhrawey
For this model of switches, if it's completely brand new with no configurations on it at all, so the console password is blank, just press enter.
"Quote for Switch Getting Started" document,
The initial configuration assumes that the switch module was never configured, that it is in the same state
as when it was received, and that it is not configured with a default username and password
 but if you have it configured before and you don't have the password, so you should go with Password Recovery Procedures.
*** Please rate this as "Answer" if it solved your problem.***
Moaz Elzhrawey
+966 596822551
Thank for answer.
If I understand correctly I do not need username for connecting via Console, is it so?
If not, then what is the username?
Br, Armands
Moaz Elzhrawey
+966 596822551
Thank you very much.
Br, Armands
