communication between multiple vrf context on fwsm
flystar35
i have 2 vrf context on fwsm of 6509 switch. i want to reach from vrf context1 inside to vrf context inside. how can i do it?
vrf_context1_inside----6509_fwsm----vrf_context2_inside
vrf_context1_inside must reach to vrf_context2_inside
Will Kerr
The FWSMs are not VRF aware.  So you would have to have two interfaces off the FWSM to route between the different VRFs.
Each VRF should have a transit to an interface in the FWSM.  From there you need to setup static or dynamic routing on the FWSM to peer / route into the VRFs.
The final piece is to ensure that you have the proper ACLs to allow communication between the interfaces, depending on the security levels.
