Configuration to reach "outside" subnet
peada04
I have a PIX 501 with a VPN configured (pool addresses are 172.1.1.0) which enables communication to the "inside" subnet (10.1.2.0) - this works fine. Now I want to extend that so that users connected to this VPN can also communicate to machines on the "outside" subnet (10.1.1.0) and out to the Internet (via gw 10.1.1.1). Is this possible? Appreciate any help!
husycisco
Level 7
Level 7
Hello Dan,
You have to permit the traffic that enterst the interface to exit the same interface, which is accomplished by "same-security-traffic permit intra-interface" command. But unfortunately, this command exists in IOS version 7.2 or greater.
Thanks for the quick answer. I guess there are no work arounds? Guess I'll just have to put the machines I want to access behind the PIX. Thanks again!
