Configuring privilege issue
nomanbari
Level 3
Level 3
I need some help here. I am trying to configure a router for access privileges.
Following is the configuration:-
enable secret level xxx
privilege configure level 14 interface
privilege configure level 14 interface shutdown
privilege configure level 14 interface no shutdown
privilege configure level 14 interface ip address
privilege configure level 14 interface no ip address
privilege exec level 14 show run
privilege exec level 14 configure terminal
privilege exec level 14 show startup
Problem is that though user can login in access level 14 but he faces two issues:-
1. sh run output is appears only as
Building configuration...
Current configuration : 80 bytes
interface Tunnel0
interface FastEthernet0/0
interface Async5
end
But sh startup is completely shown with all the information.
2. User can enter interface config mode but if he tries to configure ip address or shutdown interface, it doesn't work.
Any help will be greatly appreciated.
--Noman Bari
mustafa_nbk
Level 2
Level 2
As startup-configuration saved in nvram so you can view the full startup-cnfiguration if you have privilege to access show startup command, While show run config run from dram, so it will show the only configurations which you have a change access.
Now to use "IP address" and "shutdown" command via level 14 user, Use following command.
privilege interface level 14 no shutdown
privilege interface level 14 shutdown
privilege interface all level 14 no ip address
privilege interface level 14 no ip
privilege interface all level 14 ip address
privilege interface level 14 ip
privilege configure all level 14 interface
Mustafa
