connecting two sites using Cisco 801 routers
bas.van.hoof
Is it possible to implement VPN using Cisco 801?
Customer is now using Lan-to-Lan ISDN connection but they want to lower the cost. Are the capabilities of these routers enough or is it better to use 1700 routers?
s.jankowski
Level 4
Level 4
According to http://www.cisco.com/go/800 you can do IPSEC with that router. I would think from a scalability and performance standpoint, the 1700 would be a better choice.
