crypto errors
cgravell
Community Member
I'm running an IP VPN over a frame-relay cloud using triple DES. There are 6 sites in a hub and spoke topology. We are running VoIP between the sites, setting precedence. The calls are ok but we are seeing some dropped packets for each call. One the Hub site, we have a 2600XM with the new AES accelerator modules running code:
c2600-ik9o3s-mz.123-8.4a.bin
but am getting errors:
sh cry eng acc st:
Errors:
ppq full errors : 0 ppq rx errors : 2366
cmdq full errors : 0 cmdq rx errors : 1
no buffer : 0 replay errors : 104645
dest overflow : 0 authentication errors : 1361
Other error : 1 RNG self test fail : 0
DF Bit set : 0 Hash Miscompare : 0
Unwrappable object : 0 Missing attribute : 0
Invalid attrribute value: 0 Bad Attribute : 0
Verification Fail : 0 Decrypt Failure : 0
Invalid Packet : 2366 Invalid Key : 0
Input Overrun : 0 Input Underrun : 0
Output buffer overrun : 0 Bad handle value : 0
Invalid parameter : 0 Bad function code : 0
Out of handles : 0 Access denied : 0
Warnings:
sessions_expired : 0 packets_fragmented : 0
general: : 0
HSP details:
hsp_operations : 0 hsp_sessions : 0
I'm going to change from this release to code c2600-ik9o3s-mz.123-9.bin which is a non-engineering release now available.
Can any one shed any light on the nature of these errors? I think the replay errors relate to packets not received within an expected arrival time window are dropped by IPSEC. The counters are for about a 10 day period.
Any ideas?
a-vazquez
Level 11
Level 11
Did you check the bug tool kit for any known issues for this IOS version??
I upgraded and now only get replay errors on the hub site with no errors on any of the crypto engines at the spokes.
I'm not seeing any drops pkts in = pkts out, but i thought that replay errors necessarily resulted in drops by their nature?
#sh cry eng acc st
Virtual Private Network (VPN) Module in slot : 0
Statistics for Hardware VPN Module since the last clear
of counters 5526 seconds ago
5896963 packets in 5896963 packets out
1737792329 bytes in 1709479514 bytes out
1067 paks/sec in 1067 paks/sec out
2515 Kbits/sec in 2474 Kbits/sec out
2544370 packets decrypted 3352612 packets encrypted
488003464 bytes before decrypt 1221481326 bytes encrypted
401024765 bytes decrypted 1336774632 bytes after encrypt
0 packets decompressed 0 packets compressed
0 bytes before decomp 0 bytes before comp
0 bytes after decomp 0 bytes after comp
0 packets bypass decompr 0 packets bypass compres
0 bytes bypass decompres 0 bytes bypass compressi
0 packets not decompress 0 packets not compressed
0 bytes not decompressed 0 bytes not compressed
1.0:1 compression ratio 1.0:1 overall
208 commands out 208 commands acknowledged
Last 5 minutes:
309189 packets in 309189 packets out
1030 paks/sec in 1030 paks/sec out
2466611 bits/sec in 2430779 bits/sec out
62371647 bytes decrypted 22885872 bytes encrypted
1685720 Kbits/sec decrypted 618537 Kbits/sec encrypted
Errors:
ppq full errors : 0 ppq rx errors : 0
cmdq full errors : 0 cmdq rx errors : 0
no buffer : 0 replay errors : 1920
dest overflow : 0 authentication errors : 0
Other error : 0 RNG self test fail : 0
Invalid Packet : 0 Invalid Key : 0
Warnings:
general: : 0
HSP details:
I need to know if the replay errors are definately pkts dropped by the engine on the tunnels - because if this is so it could explain where the VOIP is dropped (All spoke-spoke Voice calls travel via the hub). I just need more of an explanation.. about this error.
Thanks guys
