Crypto Map on a BVI interface
dhcchan
Hi there,
I got a serial interface as a member of bridge group 1. An IRB bridge with interface bvi 1 has been created. IPSec tunnel is supposed to between this serial interface and remote site. A crypto map has been configured under BVI 1 interface. However, we find that packets are decrypted in this router, but no packet is being encrypted from a command "show crypto engine connection active", there is no increase in Encrypt column.
May I ask is it feasible to implement crypto map in BVI interface. And is there any alternative for this case?
many thanks
David
gfullage
Try applying the crypto mapo to both the BVI and the physical serial interface. Other than that, can you post your config (xxxx out your passwords, etc) for us to have a look at.
I have tried to apply crypto in both serial 0/0.1 and and BVI interface, but still fail.
The config is as below for your reference.
Current configuration : 3341 bytes
! Last configuration change at 15:59:33 HKT Sun Mar 30 2003
! NVRAM config last updated at 16:23:31 HKT Sat Mar 29 2003
version 12.1
no service single-slot-reload-enable
service timestamps debug datetime localtime show-timezone
service timestamps log datetime localtime show-timezone
hostname STK
logging rate-limit console 10 except errors
enable password 7
username STK password 0
clock timezone HKT 8
ip subnet-zero
no ip source-route
no ip finger
no ip domain-lookup
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
crypto isakmp key cisco123 address 10.1.250.69
crypto isakmp key cisco123 address 10.1.250.165
crypto ipsec transform-set myset esp-3des esp-md5-hmac
crypto map Serial0/0.2 10 ipsec-isakmp
set peer 10.1.250.165
set transform-set myset
match address 104
crypto map Serial0/0.1 10 ipsec-isakmp
set peer 10.1.250.69
match address 104
chat-script dialout "" "AT" TIMEOUT 30 OK "ATDT\T" TIMEOUT 90 CONNECT \c
chat-script reset "" "AT&FS0=1&C1&D3&K3&Q6&Q5&Q9" "OK" ""
call rsvp-sync
cns event-service server
bridge irb
interface Loopback0
ip address 10.1.252.14 255.255.255.255
interface FastEthernet0/0
ip address 10.1.18.1 255.255.255.0
duplex auto
speed auto
interface Serial0/0
description STK DL682060
mtu 1800
bandwidth 96
backup delay 0 20
backup interface Async65
no ip address
encapsulation frame-relay IETF
no ip mroute-cache
no fair-queue
cdp enable
interface Serial0/0.1 point-to-point
bandwidth 64
frame-relay interface-dlci 301 IETF
bridge-group 1
interface Serial0/0.2 point-to-point
bandwidth 32
ip address 10.1.250.166 255.255.255.252
frame-relay interface-dlci 207 IETF
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Async65
description PHONE NO. 26972489
ip address 10.1.250.26 255.255.255.252
encapsulation ppp
ip ospf network broadcast
dialer in-band
dialer map ip 10.1.250.25 name STK modem-script dialout broadcast 27203657
dialer-group 1
async default routing
async dynamic routing
async mode dedicated
fair-queue 64 32 0
pulse-time 1
ppp authentication chap
ppp chap hostname HQ
ppp chap password 7 052A202B
interface BVI1
bandwidth 128
ip address 10.1.250.70 255.255.255.252
ip ospf network point-to-point
ip ospf priority 0
router ospf 1
log-adjacency-changes
passive-interface FastEthernet0/0
network 10.1.0.0 0.0.255.255 area 1
ip kerberos source-interface any
ip classless
no ip http server
access-list 1 permit 10.1.0.0 0.0.255.255
access-list 1 permit 10.0.0.0 0.0.0.255
access-list 104 permit ip 10.1.18.0 0.0.0.255 10.0.0.0 0.255.255.255
dialer-list 1 protocol ip list 1
bridge cmf
bridge 1 protocol dec
bridge 1 route ip
dial-peer cor custom
banner motd ^CC
AFCD NT South Animal Management Centre!!!
^C
line con 0
transport input none
line aux 0
exec-timeout 0 0
script startup reset
script reset reset
modem InOut
transport input all
stopbits 1
speed 38400
flowcontrol hardware
line vty 0 4
exec-timeout 60 0
password 7
login
no scheduler allocate
ntp clock-period 17179778
ntp server 10.1.252.5
ntp server 10.1.252.6 prefer
end
Reapply the crypto map to the serial interface also, then on both the serial and the BVI do "no ip route-cache" and see if that works. There's lots of bugs in 12.1 code with fast switching and IPSec and virtual interfaces.
