CS-MARS Rules/Case Problem
hower_pan
Community Member
Hi every body my name is Hower
I have implement cs-mars20 Ver is 4.1.2
and i have define some custom rules and create some case.
and i want to delete custom rules and cases, i search all documents, but i don't see any drop function.
have anyone solve this problem.. please help me thank you..
pmccubbin
Level 10
Level 10
Hi Hower!
You cannot delete rules at all as it would corrupt the SQL database that is used with MARS. You can only deactivate rules so they won't produce events. Once you create a rule it lasts until you wipe the box clean and reload the software.
Hope this helps.
