CSA 4.0 to 4.5 upgrade question.
rvaguilera
I've done an in-box upgrade of my CSAMC server which actually installs an instance of 4.5 to run in parallel to the existing 4.0 installation so you can migrate your clients over to the new version.
After you have migrated all your agents to 4.5, how do you uninstall the 4.0 instance from the CSAMC?
rvaguilera
bump
Use the instructions here:
http://www.cisco.com/en/US/products/sw/secursw/ps5057/products_installation_guide_chapter09186a008042330a.html#wp962990
You should be presented with two selections:
Security Agents
Security Agents V4.5
Just as it appears when you log into Ciscoworks and access the 4.0 management center, the one without the version number is your 4.0.x version to be uninstalled.
