11-06-2006 08:59 AM - edited 03-09-2019 04:47 PM
Hi folks,
i have a question about policies in CSA
Hi folks,
where can i find a predefined modul for MS Exchange Mail Server in CSA 5.1 ?
i see a lot of predefined moduls for linux but not for MS.
thanks for your help
Klaus
Solved! Go to Solution.
11-09-2006 09:59 AM
Nicely done, thanks for the info. I'll keep this reference handy if and when we move to Exchange...
For some reason, I cannot rate your post....
If someone else would be so kind...
Tom
11-06-2006 09:07 AM
There aren't any that come with v 5.1.
11-07-2006 10:46 AM
I have run into the same issue. A solution that I used is to download the "Cisco Security Agent for IP communications", specifically, for unity (unity depends on exchange heavily) and import the policies/rules into the CSA MC. Then find the relevant policies/rules for exchange and copy them. Use the copies to make your own exchange policy. Here is the link to download the CSA for IP Communications: http://www.cisco.com/pcgi-bin/tablebuild.pl/unity3d
Hope this helps
M
11-08-2006 03:22 AM
Hi mkirbyii,
thank you very much for your help.
i have downloaded the software and now we configure our own policys ;-)
thanks
Klaus
11-08-2006 07:39 AM
Hi mkirbyii,
this was a very good idea now it works
thanks again ;-)
Klaus
11-08-2006 05:57 PM
Glad to help!
take care
M
11-09-2006 09:59 AM
Tom
