CSA figuring out a system function call from a buffer
Patrick Laidlaw
Level 4
Level 4
I have an event which system functions are executed from a buffer. I would like to figure out if there is a way to match just that pattern for that function that the software calls or not.
Atypical System Behavior Checks
Access system functions from code executing in data or stack space
Included patterns: ?
Here is the event:Text
Event Text TESTMODE: The process 'C:\Program Files\Land Desktop 2005\acad.exe' (as user SomeCompany\SomeUser) attempted to access a resource which would have resulted in the user being asked the following question. 'The process C:\Program Files\Land Desktop 2005\acad.exe is attempting to invoke a system function from a buffer. Do you wish to allow this?'
Event Time 2/9/2006 9:26:05 AM
Code ACL_QUERY_RSP_TESTMODE
PInt 407306247
PInt2 178
PString C:\Program Files\Land Desktop 2005\acad.exe
PString2 UID=SomeCompany\SomeUser>QID=424>HID=C:\Program Files\Land Desktop 2005\acad.exe
PString3 The process C:\Program Files\Land Desktop 2005\acad.exe is attempting to invoke a system function from a buffer. Do you wish to allow this?
args(6) LoadLibraryA
time 4761.1 (seconds since boot)
type APICALL
ProcessId 2592
ApiOperation BufferOverflowDetected
Credentials os=win32,T=SomeCompany\SomeUser,t=0105000000000005150000006750B36C5763DF0A3E753C37F1030000,G=SomeCompany\Domain Users,g=0105000000000005150000006750B36C5763DF0A3E753C3701020000
ApiPInt1 1635214387
ApiPString1 10005356 577471ff 7508ff15 40817f61
8bf885ff 7462688c 9e806157 ff156880
ApiPString2 LoadLibraryA
ApiPInt2 1244276
ApiPString3 90fc1200 33647761 10252b01 582bd004
502bd004 10502b01 10502b01 b4fc1200
b25b7761 10252b01 00000000 582bd004
bcfc1200 20262b01 10252b01 51000000
args(4) C:\DOCUME~1\SomeUser\LOCALS~1\Temp\AdskCleanup.0001.dir.0001\~de7039.tmp
ApiPInt3 1635214371
argi(4) 3
FlattenedForm (t-1139509565 n-141048400 z--32400 sm-152 sc-13 dm-1 dc-7 cd-834 p*(i-407306247 i-178 w-C:\Program%20Files\Land%20Desktop%202005\acad.exe w-UID=SomeCompany\SomeUser>QID=424>HID=C:\Program%20Files\Land%20Desktop%202005\acad.exe w-The%20process%20C:\Program%20Files\Land%20Desktop%202005\acad.exe%20is%20attempting%20to%20invoke% 20a%20system%20function%20from%20a%20buffer.%20Do%20you%20wish%20to%20allow%20this? a- a- a-LoadLibraryA a- r*(type-17 time-47611 pnd-83914536 rapi*(pid-2592 op-8 p*(i-1635214387 d-qaWuwDfDX9FDi8Ffaf4FHTi-f-pDIHgJEcyyx9FfObi a-LoadLibraryA i-1244276 d-qYVeamdz3fgeLSsayTc0ea1kqtaeqTsaqa1kbql*saGSBDxyquYkbaaaaaawRanb8YVeaaIjReaeLSsarbaaaa a-C:\DOCUME~1\SomeUser\LOCALS~1\Temp\AdskCleanup.0001.dir.0001\~de7039.tmp i-1635214371 i-3 ) cr-Owin32%00TSomeCompany\SomeUser%00t0105000000000005150000006750B36C5763DF0A3E753C37F1030000%00GSomeCompany\Domain% 20Users%00g0105000000000005150000006750B36C5763DF0A3E753C3701020000%00 ) ) ) )
Thank you for anyone that helps all posts will be rated reguardless of useful content.
Patrick
tsteger1
Level 8
Level 8
AutoCAD has been notorious for setting off CSA alarms. There was a bug fix published either last year or the year before for AutoCAD Lite because of it's behavior and we had to create exceptions for the network licensing application.
My solution was to add the acad.exe and aclt.exe executables to an application class that is allowed to write into memory owned by other processes and allowed to invoke system functions from code executing in data or stack space as long as the executable resides within the proper directory structure.
This seemed to be the least risky and most comprehensive exception because the patterns varied too much to make specific exceptions.
Hope this helps..
Tom S
Tom,
Thankyou for your reply with a little playing around I created an system api rule that would allow acad.exe to execute system function's from a buffer.
Included patterns: *\LoadLibraryA\*
*\VirtualProtect\*
Patrick
Tom,
*\VirtualProtect\*
Patrick
