CSA MC v4.0.3.720 install problem
d.rehfeldt
System configuration:
Windows dir. C:\WINNT\
Windows System dir. C:\WINNT\system32\
Operating System Windows 2000
OS version 5.0
Service Pack Service Pack 4
Drive(s) available C, E, F, G
Free space on C 1,943,960 Kbytes
Free space on E 8,132 Kbytes
Free space on F 4,073,380 Kbytes
Free space on G 41,191,144 Kbytes
Boot-up drive C:
Processor type CPU is a pentium
Install engine 32-bit engine
Network type LAN Support
Network driver wfwnet.drv
I extract the files, run the verify_digests.exe successfully (no errors), read the CSA_4.0.3.readme file (requirements met), run setup.exe and the installation fails after the InstallShield extracts the files and starts the installation. The error messages i: "ERROR: InstalledShield Installation logfile is corrupt. Setup cannot proceed. Will abort now."
The CSAMC-Install.log file output:
[9-10-2004 08:51:27]: Maintenance: TARGETDIR is C:\WINNT\
[9-10-2004 08:51:27]: Searching for CSAMC
[9-10-2004 08:51:27]: Validating TARGETDIR= C:\WINNT\ vs MC installed root directory g:\cscopx\CSAMC
[9-10-2004 08:51:27]: ERROR: InstalledShield Installation logfile is corrupt. Setup cannot proceed. Will abort now.
[9-10-2004 09:11:48]: Exiting from the setup...
I have downloaded the fcs-csamc-4.0.3.720-w2k-k9.zip file several times now. I have deleted the log file between attempts. TIA
mcvosi
If you have CSA running on the server, maybe stop the service when extracting the files and running setup?
Thank you for the suggestion. I have tried that too.
