CTR 2.0.4.135 autoupdate failure
Volker Janusch
Level 4
Level 4
Dear Madam or Sir,
the floowing failure occured:
"Alarm Status: Auto update failed using ftp://ftp-sj.cisco.com/cisco/crypto/3DES/ciscosecure/ids/ctr/updates/ctr-updates-2.0.xml. Please correct! (Failed to open url "ftp://ftp-sj.cisco.com/cisco/crypto/3DES/ciscosecure/ids/ctr/updates/ctr-updates-2.0.xml". null)"
The page to download the updates manual is accessible. I updated the database with the manual update file "ctr-policy-2.0.4.137.S117-K9.exe". It works.
If I try to connect the url "ftp://ftp-sj.cisco.com/cisco/crypto/3DES/ciscosecure/ids/ctr/updates/ctr-updates-2.0.xml", the browser (proxy) sends the following information:
"The following URL could not be retrieved: ftp://ftp-sj.cisco.com/cisco/crypto/3DES/ciscosecure/ids/ctr/updates/ctr-updates-2.0.xml
Squid sent the following FTP command:
CWD cisco
and then received this reply
/cisco: Permission denied"
Is there a mistake with the access rights?
Best Regards.
Volker
Manager DC-Networking, Automation & WLAN
Logicalis GmbH
cskipper
CTR does not support FTP. Replace ftp:// with http://
Thank you for this hint.
After replace ftp:// with http:// the following failure occured:
failed to get http protocol response code when opening url "http://ftp-sj.cisco.com/cisco/crypto/3DES/ciscosecure/ids/ctr/updates/ctr-updates-2.0.xml"
I can connect this url with CRT-Servers browser without any failure.
Logicalis GmbH
use:
CTR appends the rest.
If this still does not work, manually download the latest update, execute it on your CTR box, then change your autoupdate location to https://localhost
We use this "manual" option sice this failure was occured. The reason for this request was to go back to automatic signature update. It was working for a long time. Where is the failure?
Should I say to the customer "bad luck"?
Logicalis GmbH
