05-26-2004 11:08 AM - edited 03-09-2019 07:31 AM
Is it possible to retore factory default after configuring A modular access 1760 router. If It is possible I will like to know how?
05-26-2004 06:33 PM
Sure. You should perform a "write erase" then "reload" from enable mode. If the IOS prompts you to save the configuration, answer no.
Hope this helps,
peter
05-26-2004 11:53 PM
In enable mode enter:-
write erase
That will delete the stored configuration.
You should then reload the router.
06-03-2004 02:36 AM
I have posted this question before to the forum. But is like the responses seems not to address the problem at hand
1) I have a cisco modular access router 1760 that came bundled with SDM. The default IP is 10.10.10.1 on the cisco ethernet interface while 10.10.10.2 was used for my laptop network card.
2) After logging in, I changed the IP address on the router Ethernet interface to a class C IP and also did thesame thing for my laptop network interface
3)I tried logging in by lauching the web browser using the new IP(Class C) but was not authorized
What I want to do is to default to the former IP that came preinstalled with the router so that I can kick off the SDM again.
I will appreciate your quickest responses
