DMZ write net problem
Hi all ,
I got the problem is in DMZ write net the running-config image copy to the notebook , however is not working , my command is :
wr net 172.16.2.1:test
Than the error message is below:
TFTP write test at 172.16.2.1 on interface1
time out attempting to connect
[failed]
But i can in terminal ping the 172.16.2.1 , after that i in LAN ( 172.16.1.1) copy the running-config can done , using same notebook .
Is it the problem is binding interface1 on DMZ not interface2 ? should i change it ? pls advise
Stanley
Patrick Iseli
Level 7
Level 7
What is the access-list and nat global or static config for that 2 interfaces?
sincerely
Patrick
6 Replies 6
Patrick Iseli
Level 7
Level 7
sincerely
Patrick
Hi Patrick ,
Is it these issue effect the block the write net?
Stanley
Usually it should work if all host have the PIX as default gateway. Do you have a router on that net that the write net does not work?
The easyest way to figure that out is enable logging on the PIX and check the loggs.
logging warning should be enough to see that.
conf t
logging on
logg buffer warning
show logg
sincerely
Patrick
Hi Patrick ,
In my PIX all interface didn't have any router , just using cross-over CAT5 cable to connect PIX DMZ interface and notebook LAN interface , however i clear the static and acl , also didn't in DMZ write net , is it DMZ can't be using write net command ? pls advise , thx
Stanley
Hi Patrick,
The problem is solve now ,i add it this command after that can write net in DMZ
tftp-server DMZ 172.16.2.0 tftp
I don't why i need add this command can work , but i belive that before i didn't using this command also can work in DMZ . But anyway thanks you for your help .
Stanley
Thanks for your feedback.
I did not know that TFTP uses just the internal interface if it is not defined with the: "tftp-server DMZ 172.16.2.0 tftp".
Cisco says = If not specified, an internal interface is assumed.
See Command reference: http://www.cisco.com/en/US/products/sw/secursw/ps2120/products_command_reference_chapter09186a00801727ae.html#wp1026054
sincerely
Patrick
