DSL/Remote location.
sfraiser
I am new to IT so bear with me. I need to know what hardware is needed to use DSL at my remote maintenance stations. I will be using Cisco 3000 VPN.
I don't want the user to be able to browse outside of VPN. Browsing is restricted when using VPN(adult sites,etc.). What type of router should I use for 10 users or less that will be programable to not allow browsing outside of VPN?
Steve
travis-dennis_2
Level 7
Level 7
If the ISP gives you anything that can be plugged into an Ethernet card I would go with a 3002 VPN Hardware client and not a router. It can be done with a router as well but I just like the 3002s for these types of scenarios. If you want to make it a router almost any router Cisco has might to the trick. You need to be a little more specific on what you have from the ISP to narrrow it down and also how mcuh you can spend on it.
afakhan
Level 4
Level 4
You can use ALL tunneling (as opposed to Split tunneling), and can use any of the following HW at the remote site to connect to your VPN3000 as the head-end:
1 - PIX-501 (cheapest)
2 - VPN3002 HW client
3- C806 router
Afaq
