01-17-2001 01:22 PM - edited 02-20-2020 09:33 PM
hello,
My question is regarding a Cisco Radius server with Dynamcic ACL.
I have one router and one Radius Security server. How a router can received a Dynamic ACL from the Radius Server in order to let the user to go in specific host or subnet ??
Thanks, Dany
01-29-2001 07:22 AM
I've done this as an ISP once. You need to use the
Cisco-AV-Pair attribute in which you may specify any router command you want to be executed for a specific user.
You'll need to use
virtual-profile aaa.
The problem is that the commands are not exactly the way you would write them in the CLI. They are from TACACS, run a search on CCO for Cisco-AV-Pair and I'm sure you'll find something usefull.
Best regards,
Cristian Caramida
02-01-2001 11:22 PM
Hello Dany,
To implement dynamic acl, your radius server should return an attribute to the router:
cisco-avpair = "ip:inacl=my_user_access_list"
this is for selecting an extended access list, already defined in the router, named "my_user_access_list"
or you could return several :
cisco-avpair = "ip:inacl#1="deny 10.10.10.10 0.0.0.0"
cisco-avpair = "ip:inacl#1="permit any any"
Those line build a dynamic access list 1.
