Encrypt traffic generated on a remote router?
Mark_Matthias
Will a router encrypt traffic from a segment it is not direclty connected to?
I created the following example to explain my question:
The subnet for all segments is 255.255.255.0
router2010 services the 10.20.10.0 ethernet segment
and has a link using 10.150.0.0 segment to router2020
router2020 services the 10.20.20.0 ethernet segment
and has a link using the 10.51.0.0 segment to router30
router30 services the 10.30 ethernet segment
I want to encrypt all traffic between both 10.20 segments and the 10.30.0.0 segment only between router2020 and router30.
My access list on router2020 reads as follows:
ip access-list extended R2020TO30-encryption
permit ip 10.20.0.0 0.0.255.255 10.30.0.0 0.0.255.255
My access list on router30 reads as follows:
Will router2020 encrypt traffic from 10.20.10.0 segment even though that traffic does not originate on a segment directly connected to router2020?
or do I have to set up an encryption between router2010 and router30 to accomplish that?
Where can I find information about this?
Mark
Richard Burts
Mark
Am I correct in assuming that when you speak of encrypting traffic that you are talking about using IPSec?
A router does not need to be directly connected to a segment to be able to do IPSec encryption for that segment. So in your example I do not see a problem to have router 2020 encrypt traffic with source address 10.20.10.0 and 10.20.20.0.
One detail: I would revise the access list on router 30:
permit ip 10.30.0.0 0.0.255.255 10.20.0.0 0.0.255.255
on router 30 the source addresses will be 10.30 and the destination addresses will be 10.20.
Rick
Rick
Yes Rick, I am talking about IPSec. Thanks for your reply.
Do you (or anyone else) know of any examples on Cisco's web pages or other documentation where I can show that this will work to my client?
Mark
