Error when sync Profiler and CAM
hi expert team ,
i have problem regarding sync profiler and cam .. i runing on this command [beacon@QAProfiler2 ~]$service profiler setupccakey and appear error.
any idea to solve this problem ?
Tiago Antunes
The Profiler dos SSH connection to the CAM.
It looks like the DNS resolution is failing for the ssh connection, hoever the synchronization is successfull.
Are you using hostname based certs?
If yes, are the hostnames resolvable?
HTH,
Tiago
If  this helps you and/or answers your question please mark the question as  "answered" and/or rate it, so other users can easily find it.
