exact serial failover plug type
chrrbc
Hello
I'm letting create a longer serial failover cable for two PIX520.
I know already the cable pinouts described in
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_61/pix_ig/apdx.htm#xtocid4
but I do NOT know which exact type of serial plug I should order. Can somebody tell me the correct plug type number or part number?
ssoberlik
Level 4
Level 4
I believe the PIX 520 has the DB-25 plug. Take a look at the connector on the back to see it its 9-pin or 25-pin. Both pinouts are in the doc.
