EZVPN question
mnewnam06
I have a C870 running 12.4(4)T2. I am using EZVPN on this router. My question is what does "Phase: 6" mean? Thanks
#sho crypto ipsec client ezvpn
Easy VPN Remote Phase: 6
Tunnel name : primary
Inside interface list: Vlan1
Outside interface: FastEthernet4
Current State: IPSEC_ACTIVE
Last Event: CONN_DOWN
DNS Primary: x.x.x.x
DNS Secondary: x.x.x.x
NBMS/WINS Primary: x.x.x.x
NBMS/WINS Secondary: x.x.x.x
Default Domain: customer.com
Save Password: Disallowed
Current EzVPN Peer: x.x.x.x
Hi Kamal,
Thanks for the reply. I have found that you are essentially correct. This phase number refers to the ezvpn client feature set running on the router.
You are most welcome :-)
Glad to know that I could provice you with the required information.
Please rate if it helpd.
Kamal
