Failover Hostname
normanzhang
Can failover PIX boxes have differ hostname? Or they need to be the same?
jackko
Level 7
Level 7
i would think so, as the fo unit sync with the primary unit including all the codes ann the command hostname is part of it.
Patrick Iseli
Level 7
Level 7
Usually the hostname is identical in failover configuration.
See the following guide:
Note: This guide bellow will not cover version 7.x.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a0080094ea7.shtml
sincerely
Patrick
jackko
Level 7
Level 7
You are 100% right, hostname has to be the same for the HA pair.
