Firewall problem
auromira
The firewall is having some problems..
1) Hard disk shows 0 mb free.Here below specified are the configurations:
Login: admin
Password:
CES>en
Password:
CES#sh ve
CES#sh version
Contivity Extranet Access Switch Software
Software Version: V04_06.120
Software Build Date: Jun 6 2002, 18:58:06
System Serial Number: 8172
Mac Address: 00-03-4B-FD-E1-0C
BIOS: PO3
Up Time: 002 11:46:34
Processor 1 Celeron 300 Mhz, L1D Cache:16K, L1I Cache:16K, L2 Cache:128K
Memory 52 MB Free, 128 MB Total.
Hard Disk 1 0 MB Free, 2047 MB Total
Virtual Diskette
2) web-browsing is not working .
3) Not able to remove static IP ROUTE by CLI.Messg. displays "does not
exists",inspite the routing is set.
Can anyone enlighten on this issue.
Thanks in advance
Auromira
gfullage
Errr, is this a Cisco firewall? Going by the "sho ver" output this looks like a Nortel Contivity switch running CheckPoint software. I doubt you'll get much help on this forum, you might want to try Nortel.
Having said that, it looks like the hard disk is a virtual disk, so my guess is that it would always show up with 0Mb free, probably not something to worry about.
You might find some help on this web site for the other issues:
http://www130.nortelnetworks.com/cgi-bin/eserv/cs/main.jsp?BV_SessionID=@@@@0777151473.1071465403@@@@&BV_EngineID=fadcjddikfdkbhkcginchgcgio.0&level=2&category=23&subtype=&subcategory=1&dispType=byCat&catOID=-8894&catState=GA
