FTP port map issue
blin
I am trying to open port 21 on router 831 for accessing FTP server. I added the fllowing two lines.
access-list 10 permit 171.16.5.2
ip port-map ftp port 21 list 10
But can telnet it. When double-checking the configuration, I don't have "ip port-map ftp port 21 list 10" line. I added it agian without error but the line doesn't show. Here is the configuration. Any suggestions?
version 12.3
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname ciscodmz
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200 debugging
logging console critical
enable secret 5 $1$o0ko$hXk18FTwq076pCcnKY0LY1
username ciscodmz privilege 15 password 7 00071A1507545A545C
clock timezone America/Regina -6
no aaa new-model
ip subnet-zero
no ip source-route
ip tcp synwait-time 10
ip domain name cisco.com
ip name-server 4.2.2.1
ip dhcp excluded-address 172.16.5.1 172.16.5.5
ip dhcp pool sdm-pool1
network 172.16.5.0 255.255.255.0
default-router 172.16.5.1
no ip bootp server
ip cef
ip audit notify log
ip audit po max-events 100
ip ssh time-out 60
ip ssh authentication-retries 2
no ftp-server write-enable
interface Ethernet0
description $FW_INSIDE$$ETH-LAN$
ip address 172.16.5.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
no cdp enable
interface Ethernet1
description $FW_OUTSIDE$$ETH-WAN$
ip address 68.17.43.208 255.255.255.224
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip route-cache flow
duplex auto
no cdp enable
interface FastEthernet1
no ip address
duplex auto
speed auto
interface FastEthernet2
no ip address
duplex auto
speed auto
interface FastEthernet3
no ip address
duplex auto
speed auto
interface FastEthernet4
no ip address
duplex auto
speed auto
ip nat inside source list 1 interface Ethernet1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 68.17.43.193 permanent
ip http server
ip http authentication local
ip http secure-server
logging trap debugging
logging 172.16.5.1
access-list 1 permit 172.16.5.0 0.0.0.255
access-list 10 permit 172.16.5.2
no cdp run
route-map SDM_RMAP_1 permit 1
match ip address 120
banner login ^CCCAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login local
no modem enable
transport output telnet
line aux 0
login local
line vty 0 4
privilege level 15
login local
scheduler max-task-time 5000
scheduler interval 500
end
ciscodmz#
Yes if this is what you want to do then the term you used and the command that you used (ip port-map) were not correct.
If you want FTP coming in to the router to a public IP address to be forwarded from the router to a private IP address, then I think a static NAT translation would be the answer that you need.
Rick
Rick
12 Replies 12
Richard Burts
What IOS are you running on the router (both release level and feature set). Are you sure that this code supports that feature? I have seen similar behaviors when a command is entered that this particular version of IOS did not support: you can enter the command, the IOS does not generate an error message, but the command is not applied in the running-config.
Rick
Rick
it is version 12.3.
12.3, but what feature set? Without knowing what feature set it is impossible to be sure whether the feature is supported on your platform.
Rick
Rick
Hi Rick,
I am not Cisco extert. Wher can I find feature set?
thanks.
There is an indicator of the feature set in the file name that Cisco gives the IOS. If you post the results of show version and of show flash we should be able to tell what feature set you are running.
Rick
Rick
Ok, here are show version and show flash. What feature set do we have?
ciscodmz#show version
IOS (tm) C831 Software (C831-K9O3Y6-M), Version 12.3(2)XC, EARLY DEPLOYMENT RELE
ASE SOFTWARE (fc1)
Synched to technology version 12.3(1.6)T
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Thu 25-Sep-03 09:06 by ealyon
Image text-base: 0x800131E8, data-base: 0x80AE4BD4
ROM: System Bootstrap, Version 12.2(8r)YN, RELEASE SOFTWARE (fc1)
ROM: C831 Software (C831-K9O3Y6-M), Version 12.3(2)XC, EARLY DEPLOYMENT RELEASE
SOFTWARE (fc1)
ciscodmz uptime is 1 day, 2 hours, 45 minutes
System image file is "flash:c831-k9o3y6-mz.123-2.XC.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
CISCO C831 (MPC857DSL) processor (revision 0x300) with 44237K/4915K bytes of mem
ory.
Processor board ID AMB08030B4L (4240108561), with hardware revision 0000
CPU rev number 7
Bridging software.
2 Ethernet/IEEE 802.3 interface(s)
4 FastEthernet/IEEE 802.3 interface(s)
128K bytes of non-volatile configuration memory.
12288K bytes of processor board System flash (Read/Write)
2048K bytes of processor board Web flash (Read/Write)
ciscodmz#show flash
System flash directory:
File Length Name/status
1 5637500 c831-k9o3y6-mz.123-2.XC.bin
2 1790 sdmconfig-83x.cfg
3 16264 sdm.shtml
4 16264 sdm.shtml.hide
5 3176448 sdm.tar
6 1462 home.html
7 1462 home.html.hide
8 216064 home.tar
9 42 SDMupload [deleted]
10 46 SDMupload [deleted]
[9067992 bytes used, 3252776 available, 12320768 total]
ciscodmz#
Thanks for posting this. I have looked at the issue again and think that I understand it better and have found an answer. I think the issue is that you were attempting to use port-map to define FTP. FTP is a system defined mapping. I found a statement in the documentation for ip port-map that indicates that you can not redefine the system defined mappings. Here is what the documentation says:
The Cisco IOS Firewall CBAC feature requires the system-defined mapping information to function properly. System-defined mapping information cannot be deleted or changed; that is, you cannot map HTTP services to port 21 (FTP) or FTP services to port 80 (HTTP).
At this point I am confused about what you were trying to do. Why were you attempting to do port-map for FTP? Is there any sign that FTP is not working other than the fact that you do not see the command that you entered show up in running-config?
Rick
Rick
Hi rick,
Thank you for the details. Perhaps, I used incorrect term. What I want is port forwarding from a public ip to a private IP. For example, when poeple access the public ip port 21, it will point to the private ip port 21. How do I configure that?
Rick
Rick
Hi Rick,
It works af adding the following line.
ip nat inside source static tcp 172.16.5.2 21 interface ethernet 1 21
thank you very much.
Kevin Dorrell
Level 10
Level 10
BTW, the reason why the line didn't appear in your config: the command "ip port-map" is used to re-map the ports associated with certain applications. The default port for the FTP service is already 21, so "ip port-map ftp port 21 ..." is already the default, and so does not appear in the config.
Kevin Dorrell
Luxembourg
Hi Kevin,
Thank you for the tip. This is very helpful.
