FWSM: Design considerations routing, PBR
d.bader
Hi Afaq
We are going to add new security to our health-care network, which connects different locations to each other. It seems to be a great solution using multiple contexts on FWSM. In fact, there is no support for OSPF routing. We provide a central remote-access solution, Internet-access and WAN connections (dual-homed) to the other locations. Static routing give me not a brief overview about the availability of partial subnets and requires lots of routing configuration for multiple contexts.
What is your recommendation? Or, how can I get dynamic routing updates from outside to inside? I guess, that a separate VLAN routed by MSFC by-passing the FWSM is not a great idea.
On the other hand, pointing inbound traffic to the right context (virtual firewall) needs PBR (policy based routing). Right?
Thanks in advance.
Daniel
jonathanstevens
You could consider allowing a dynamic routing protocol to pass though the firewall devices, and use the transparent firewall option. However, I think you would need to consider the security implications of doing so very carefully, and secure the routing protocol itself as much as is possible (e.g. authentication, encryption, redistribution control, etc.).
Another option might be to consider using SAA probes and tracking, as per the recent article in packet magazine.
look at cisco.com/packet/162_4a2
and cisco.com/packet/162_4a3 for more info.
